Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: No spark on 3 & 6
    No spark on 3 & 6
    Like the title says car is not getting spark on 3 & 6 i thought it was the ptu but didnt solve the problem HELP!!
    Ecu has been rebuilt my last guess is the ignition coil
    Medford OR
    What year car?
    Stealth ES 91
    Medford OR
    OK, that eliminates out of phase CMP/CKP sensors.... You can check for a coil problem by simply swapping coils and seeing if the problem follows the coil. You should also closely check the connectors at the PTU and the coils. I've seen the pins get pulled out of the connectors, and not make a connection, even while appearing to be connected externally.
    Ok thankz ill check the pins tomorrow right now its really cold outside
    Sep 2011
    Ooooor check the cas. Had the exact same problem after and autox, bought a new coil no luck, did some digging to discover if the crank angle sensor is off in the timing that you will see this oddball issue, sure enough, pulled the timing covers off and I was off a tooth. For whatever reason, the ecu won't fire the coil at all if the crank angle sensor doesn't properly overlap the cam angle sensor
    Medford OR
    Quote Originally Posted by arm0red1 View Post
    What year car?
    Quote Originally Posted by DarK_sTyLe View Post
    Stealth ES 91
    OK, that eliminates out of phase CMP/CKP sensors.....
    91-92 cars don't have separate sensors...
    Player Hater of the Year
    San Antonio, TX
    Coil!
    i have checked the pins and harness and they all look good.... ill change the coil tomorrow
