Yeah I don't blame you for changing it. I really hope my rivets aren't wearing out. I've been worried about that, damn spec! :shakesfist:
This.
Yeah, bronze clutch disc + lightweight flywheel doens't go well together from what I've read from Supra guys. If you're going with a bronze clutch, go with a stock flywheel.
I would be worried about compromising the integrity of the hub disc with the heat of welding. The clutch manufacturer who centered and re-riveted my 4+ had the same concerns when I mentioned welding. That's a thin plate, hope it never blows apart on you.
Too easy to stall with a lightweight flywheel IMO. Not a fan.
Running the fidanza with a clutch masters stage 3 clutch...400 miles on the new build..so far so good. Brand new TOB squeeks though just like yours...![]()
I did concider that but I decided it was worth a go after hearing that others had done the same.I would be worried about compromising the integrity of the hub disc with the heat of welding. The clutch manufacturer who centered and re-riveted my 4+ had the same concerns when I mentioned welding. That's a thin plate, hope it never blows apart on you.
Jeff![]()
ok, so sounds like ill use the money elsewhere. def need to replace my output shft seal and new TOB.
I think this is opinion only. Did anyone ever quantify in the 1/4 which is faster? If so, I don't remember it. The main argument to staying with the stock flywheel is that it carries much more rotational mass, and as such, makes it easier to get the car moving when the clutch is engaged. Having a LW flywheel makes it harder to overcome inertia and you are more likely to bog on launch.
HOWEVER... I don't have any problems bogging. When you've got a CFDS and lightweight wheels, fiberglass hood, lightweight battery, underdrive pulley, and other weight reduction, it is easy as pie to get the car moving with a LW flywheel. To this day, I don't think anyone has ever done a few back to back runs just with swapping out the flywheels and seen which setup was faster. If someone has, please chime in and post results.
