Results 1 to 5 of 5
Thread: Need Bearing Part #'s
    Never finishes any verified
    Wake Forest, NC
    If anyone has the transmission bearing part numbers I am needing to know the part numbers for the intermediate shaft bearing and the output shaft bearing, Both bearings are on the end case side.
    Rock auto is showing Part # 32009x and 32010x but I don't know which is which.
    Need to get these ASAP as I need to get these bearings on order.
    Thanks Everyone!!!
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    Wake Forest, NC
    Anyone?!?!?!?
    Banned J. Fast's Avatar
    Input shaft bearing is 7133-07066336 from National Bearing (Transtar). They should be around $20 or so. The larger bearing is 7133-07066344, those are about $30.
    Not sure about the OEM part number, but that bearing is the same as the oem bearing. I took the part number off of the package sleeve on a full 6 speed rebuild kit I have on hand.
    Wake Forest, NC
    Are those just the bearings for the intermediate shaft or is one of them the output shaft end bearing mounted to the VCU cover??
    Here is what I found but it states 6spd.... I need 5spd or are they the same: 96 1996 Mitsubishi 3000GT Manual Trans Intermediate Shaft Bearing - Transmission - National, Left, Right - PartsGeek
    According to this site those part numbers are for the left and right intermediate shaft bearings.....
    They are the same...
