Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: rear precat help
    Quote Originally Posted by dbest671 View Post
    The OP never said it was a 3sx precat eliminator... and the one from 3sx is drilled for both 1st gen and 2nd gen (ie: 2 holes on each side)
    And I went downstairs to look at my downpipe (2nd gen), and now I almost 100% positive that is a 2nd gen. Do you have a universal downpipe or generation specific?
    Very true, that was a dangerous assumption on my part, but it does look like a 3x with a corner ground off.
    TN
    Quote Originally Posted by smoking rr View Post
    The 2 holes on each side shouldnt effect where it lines up to the brace. I have no clue what brand it is. I bought it used 3 years ago.
    Sent from the bat cave
    Do you still have your original precat? If so, have you tried mounting it to see if it hit the bracket? It could be the way the precat is welded, as in incorrectly.
    No I dont, I sold them a few years ago after I bought these. Guess I will just make it fit and then make the down pipe for it.
    1991 Stealth RT/TT forged crank, new pistons/bearings/rings, T16's ceramic coated, precat deletes ceramic coated, full exhaust, FMIC, Dijon intake pips, adjustable cam gears.
    Banned J. Fast's Avatar
    I've installed their precats as well as T1 TD-04 header/precat kits. They pretty much all do that. Basically you have to redeck the precat to turbo flange to get the downpipe aligment correct. Take a straightedge and scribe a flush line on the flange whe the precat is installed. Take the flange to a belt sander and redeck it.
    Another thing I've found with the kits, you have to pull the bracket and shave about a 1/8" off the shoulder of the dowpipe flange. You also have to install the trans as the bracket will shift out of the way when fitted.
    Lastly, when you test fit the engine with the trans and all plumbing/piping installed you'll find you have to use a peen hammer and dent the precat so it doesn't clip the subframe.
    When you fit the engine fully assembled... trans, manifolds, turbos and make those adjustments the bracket will mount.
    A question back at you, do you have a solid dowpipe or does it have a flex section in it? Reason why I ask, the precats sometimes crack if the dowpipe is solid.
    Damn that sucks. I don't have a down pipe yet, I an buying things as I get to that point. This has been a 3 year build with most of the putting back together happening in the last month or so.
    can you borrow a downpipe from someone local to make the adjustments?
    i dont know if i can or not, i am not really worries about matching it to a downpipe, i just want it to fit in the car, once it fits i can have a downpipe modded to fit.
