not going to help that much, when you run the wheel further inboard you start to hit the frame with the tire at full lock anyway :|
1996 GTO, Owner since 2003.
at 19x10+42 with a 285/35R19 at full lock it JUST hits the rails, this is with the alignment at 0 camber, keep in mind this is a larger than stock OD, but you get the idea.
most race tire's are wider than the same size road tyre as well :| it's why I'm keeping an eye on Permenant grin's DR1400 build...see how the R888's go against his shocks.
i dont think during road racing you normally do any full tilt turning correct?
also permenant grin also went wider on the offset too with a wide body kit.
you'd definitely not do any full tilt turns unless your going hairpins or something, you don't want your tires contacting the rails no matter what your doing though so if your going a custom setup you need to keep in mind the bearing center-line etc (but then I don't need to tell you any of this), and yeah he did, quite a few of us think there will be oodles of room between his tire and shock to have had a higher offset (and improve things like the bump steer/ increase the lifespan of bearings etc)
A nice flowing 4'' downpipe would be nice to see.
more or less, yes.
assuming you have a pivoting bracket that goes between the lower A arm and the bottom mount of the shock, a bracket could be made to suite any shock lower mount if you get what I'm saying
315/30/18 R888's
Rays Volks TE37SL 18 x 10.5 ET +15
