Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Windows System Repair
    Guys, the touchpad/mouse works fine. I'll try some of the ideas suggested tonight and report back. Wish me luck.
    Still working on this with no success
    Before 3Si.
    Outer Banks
    Can't expect us to shoot in the dark unless you tell us what you have done. You're obviously having a driver based issue/conflict. Did you try the steps I outlined?
    Quote Originally Posted by OBXBoost View Post
    Yes, it was already installed. I re-installed it with no success.
    I should be more clear. In Vista, you use F8 to get to the advanced options menu. From there you're supposed to select "Repair my computer" and this takes you to etc... My problem is that when I select "repair my computer" my computer just starts up as usual. If you guys need a video I can take one later tonight, just let me know.
    JNS Engineering verified
    San Jose, CA
    hid.dll error message on reboot - Microsoft Answers
    It is possible that a USB device that you have installed on your system has corrupted the HID.DLL file. This file is essential for processing interface devices. You may check the following KB article for a hotfix that replaces this file: A Bluetooth device is unavailable after you perform a suspend-and-resume operation in Windows Vista
    Or if the above does not relate to your issue you may attempt any one of the following:
    Run The System File Checker tool:
    To determine whether the issue that you are experiencing is caused by one or more system files that are used by Windows Vista, run the System File Checker tool. The System File Checker tool scans system files and replaces incorrect versions of the system files by using the correct versions.
    To run the System File Checker tool, follow these steps:
    1. Click StartCollapse this imageExpand this image, and then type cmd in the Start Search box.
    2. Right-click cmd in the Programs list, and then click Run as administrator. Collapse this imageExpand this imageIf you are prompted for an administrator password or confirmation, type your password or click Continue
    3. At the command prompt, the following line, and then press ENTER: sfc /scannow
    When the scan is complete, test to see whether the issue that you are experiencing is resolved. If the issue that you are experiencing is not resolved, use the procedure that is described in the "The System Restore tool" section.
    Do you know when you began receiving this error? You may attempt a system restore to the point where you last had a working boot procedure. Make sure that any USB devices you might have installed since then are monitored in case they generate the same error again, there could be a compatibility issue between it and your operating system.
    Undo system changes with System Restore:
    Turn back time on your PC&#58; Undo system changes with System Restore
    If the above fails then you may choose reinstall your copy of Vista while keeping your files, settings, and programs by performing a repair installation or an upgrade installation.
    1. Insert the Windows installation disc into your computer's DVD or CD drive. You must start Windows installation while running your existing version of Windows.
    2. On the Install Windows page, click Install now.
    3. On the Get important updates for installation page, we recommend getting the latest updates to help ensure a successful installation and to help protect your computer against security threats. You will need an Internet connection to get installation updates.
    4. On the Type your product key for activation page, we strongly recommend that you type your 25-character product key to help avoid problems during activation.
    5. On the Please read the license terms page, if you accept the license terms, click I accept the license terms.
    6. On the Which type of installation do you want? page, click Upgrade to begin the upgrade. You might see a compatibility report.
    7. Follow the instructions.
    Note: If your installation disk does not include SP1, and you are updated to it, then you will have to uninstall it before performing an upgrade install. Start -> Control Panel -> Programs -> View installed updates, then select Service Pack for Microsoft Windows and click Uninstall.
    It is always advisable to backup any and all important data before proceeding with any major changes to your system. Methods for backing up your files: Methods for backing up your files
    Always make sure you have a means of reinstalling your programs, either through an install disk or having access to the installation files.
    Let us know your results. Thank you for using the Microsoft Vista Support Community.
    Rami
    Microsoft Answers Support Engineer
    Visit our Microsoft Answers Feedback Forum and let us know what you think.
    Before 3Si.
    Outer Banks
    Have you tried the standard gamut of antivirus/antimalware tools?
    Malwarebytes
    Superantimalware
    Spybot
    Ad Aware
    Combofix (at least on x86 OS's)
    I'd also download and install the free trial of AVG ANTIVIRUS only, not the Internet Security Suite and have it do a complete scan.
    Usually these are the first things I will use once I also start seeing driver errors just to be sure.
    Yes, I use MB frequently as well as others. I manually repaired the DLL file and everything appears to be working as it should. Although I still have the clutter that a factory image restore would have gotton rid of, I'm not too worried about it.
