Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: subframes
    Quote Originally Posted by Gearheadvr4 View Post
    Axels are different because of the trans or the rotors being larger?
    axles are different because of trans. for example, my fwd > awd conversion required different axles--even though the transmission remained atx.
    Curious as to why they are different also??
    The trans, axles and hubs are the same?!?!?
    no, but they are interchangeable. (axles must match hub).
    ok there is a 95 dohc fwd m/t in a pick n pull yard i am going to get. I just need the sub frame and controle are to powder coat
    The axles are actually pretty much the same down to the splines. The major factor is length. I could put the VR4 knucles on my car and my FWD axles will fit with no modification. Hell I could even pop my axles into an AWD trans. The only FWD axles that can't do that is 91-92's because they have a smaller diff.
