Results 1 to 10 of 14
Thread: subframes
    subframes
    i want a front subframe to powdercoat and was woundering if the na subframe is the same as the tt?
    The rear subframe? Not even close.
    Front one is the same IIRC.
    Never finishes any verified
    Wake Forest, NC
    Front is the same!
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    Thank you, What about the lower controle arms?
    iirc, virtually everything is the same (or is interchangeable) on the front for n/a vs. tt....except for axles.
    As long as the front control arms aren't from a SOHC, you will be fine. Must be DOHC arms
    Riding topless!! verified
    Owned 8 3s since 2005.
    Corpus Christi
    Axels are different because of the trans or the rotors being larger?
    Wake Forest, NC
    Curious as to why they are different also??
    The trans, axles and hubs are the same?!?!?
    Feb 2011
    NE oHIo
    I got used replacements for a car and found that a few of the holes on the right side didnt line up properly. I think there is a difference between auto and manual trans.
    -SP
