I've attached a chart I've found in some other ECU Flash Tuning threads. I do have a question as far as the 880cc PTE injectors go, which row in the table is best for them?
Tuning fuel injectors takes a lot of closed loop driving. Your fuel trims will tell you how to adjust the voltage scaling. I wouldn't worry about any other cells outside the 12v & 14v range.
Take any one of those rows and test it out. They all should be close enough to at least get the motor running.
Car started up fine. Did a moderate cruise down the road for about 20 minutes and that was fine as well. So far so good first time flashing the ECU. Was there ever a fix to get EVO Scan to monitor the front fuel trims? I'm on version 2.7 of EVO Scan.
