I was the victim of a hit and run in my college parking lot recently and thankfully it didn't do too much damage, just busted the driver's turn signal and moved the fender back a bit. I decided to replace the busted turn signal with clear corners. installation went fine but when I try to use the warning lights, nothing works. everything else is fine; brake lights, reverse lights, driving lights, brights, turn signals, but when I hit the warning lights button, nothing happens. I dismantled them and plugged back in the old bulbs and everything was fine again. help?
Edit: I bought them from 3sx. using the amber bulbs that came with the lenses seemed to cause the problem. re-installing the clear bulbs seemed to fix the problem, don't think it's legal though.
