Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Wheel Speed sensor
    March 2007
    Muskogee, Oklahoma, United States
    THAT might be easier than pullin' these sensors. But I wonder if that will fix the idling up issue
    I dont think the idle up issue has anything to do with ABS. You may have a vacuum issue with the booster.
    Member
    Chilliwack BC
    Yes, that fixed the high idle issue for me (2k rpm) the problem would come & go-ABS light would stay on when problematic.
    March 2007
    Quote Originally Posted by Primus101 View Post
    That's what mine is doin'. But since I pulled the relay, it does it all the time. Even when I don't hit the brake. But idles down when I get down to about 10mph.
    Member
    Chilliwack BC
    The ABS module raises the idle to compensate for engine braking- sorry, cant figure out how to copy & paste it from the FSM, but there is info in the '91 Stealth manual page 5-31
    I attempted to pull the relay & fuse to no avail- only when I unplugged the module did it correct itself. Takes like 5 minutes to get to & unplug, try it & thank me later....that high idle just about drove me nuts!
    March 2007
    I will.
    Member
    Chilliwack BC
    Hmmm, just read now the idle increase for ABS applies to AWD- You're FWD?
  8. #18
    March 2007
    I have 1 of each. This is for the VR4.
