Results 1 to 10 of 27
Thread: Help mass airflow
    Apr 2011
    buffalo NY
    Help mass airflow
    I just finished making my car TT for the second time but it will only stay running with the mass airflow unplugged if u plug it in it runs like crap then stalls but with it un plugged it runs I don't have any vac leaks I checked over everything today... Any ideas
    1991 3kgt sl, all forged internals, 450cc injectors, 13t's, eBay turbo back, walbro 255, hks ssqv bov,turbo smart mbc, 3sx fuel loop, 3sx polly mounts, 3sx dual core rad, FMIC, 99 big bore lifters, xtd stage 3 clutch
    Medford OR
    What engine harness and ECU are you running?
    Apr 2011
    buffalo NY
    Jdm ecu and harness with 1 o2 sensor
    Medford OR
    Check for a missing or damaged fuel pump relay or fuel pump resistor... Pretty common symtom of not having any power to the fuel pump in resisted mode.
    Cazenovia, NY
    Are you logging at all? Do you have a MAF reading? Sounds like a bad MAF to me.
    Apr 2011
    buffalo NY
    No I gotta get a logger and I have a new resistor pack how do I test my mass airflow?
    Apr 2011
    buffalo NY
    Also on my rear precat I haven't put my egr block off plate on yet so that is open don't know of that would do anything or not
    Rofl I know someone else with that issue
    car literally runs fine with the MAF unplugged right? as in you can rev it to 5000+rpm and seems ok?
    1996 GTO, Owner since 2003.
    Apr 2011
    buffalo NY
    Yes that Is what mine is doing I can take it to 7k and it is good just runs really lean
    ok, we have tried replacing the MAF, no fix, checked the spark plugs + leads...no problem
    the guy who's car it is suspects PTU?
    that or you could try checking the leads to your ECU maybe? from what I'm aware a few people have experienced it but no-one has found out why.
