Results 1 to 6 of 6
Thread: TT engine swap
    TT engine swap
    Hey guys im thinking about swapping the motor in my 92 SL with a TT motor from a 93 RT. What other things will I need to do the swap? Thanks in advance for your help.
    Are you just wanting to do the engine or turbos and everything?
    http://www.3sgto.org/f19/tt-conversi...hread-292.html
    This has everything you need to know.
    Start reading
    Honda Eater
    April 2007
    Ontario, Canada
    eek... that thread will help him, but not much... he's swapping in a 93 engine!... it might have mixed parts from both 1g and 2g
    No no and no. Its not hard at all to put a 93 engine into a 92. The CAS on the 92 will pop right into the 93's rear head. Everything else should be the same
    Quote Originally Posted by Mike-92RT View Post
    Are you crazy? Everything is there, just have to read.
    He said your snippet because he thinks that the 93 engine in a 92 is difficult, when in fact it is straight forward.
