Hey guys im thinking about swapping the motor in my 92 SL with a TT motor from a 93 RT. What other things will I need to do the swap? Thanks in advance for your help.
Are you just wanting to do the engine or turbos and everything?
http://www.3sgto.org/f19/tt-conversi...hread-292.html
This has everything you need to know.
Start reading![]()
eek... that thread will help him, but not much... he's swapping in a 93 engine!... it might have mixed parts from both 1g and 2g
No no and no. Its not hard at all to put a 93 engine into a 92. The CAS on the 92 will pop right into the 93's rear head. Everything else should be the same
He said your snippet because he thinks that the 93 engine in a 92 is difficult, when in fact it is straight forward.
