I've started my car when I was first building it without any exhaust and no maf. The only think I was just talking to him about today, was the mix and match of everything, the computer might not be getting a signal from the crank sensor. (In his case, its in the case) But he just bought, i believe, 95 harness, ecu and is seperating the cam and crank.
Btw b-man, I like your signature!
i bet you swapped the cams and exhaust is getting back into the intake which is why it wont start back up after dying & needs to sit to clear the intake back out before starting again.
He said they didn't know if the cams were right, so that could be a very good possibility!
The cams are out of a 95 sl I think the heads have a cas sensor and the ecu is for a 92 vr4
the rear ones if I remember correctly you can turn by hand something was odd with them
1991 3kgt sl, all forged internals, 450cc injectors, 13t's, eBay turbo back, walbro 255, hks ssqv bov,turbo smart mbc, 3sx fuel loop, 3sx polly mounts, 3sx dual core rad, FMIC, 99 big bore lifters, xtd stage 3 clutch
Wow...anything could be wrong,using NA wiring and ECU with TT engine a big NO.You saying mechanically cams could be wrong and in wrong position?
It is impossible to give a good advise if basics like wiring,fuses,sensors not connected or missing+mechanical mess
Man i truly hope you'll fix this thing.Good luck
Pretty much this
It's pretty much shooting in the dark here. I'd start with checking timing and cams, make sure they aren't swapped around. I'm not sure if I missed it but what injectors? If he is using a NA ECU without some fuel control that can be the problem. I know quite a bit about TT conversions, I wish I could be there to help.
He has vr4 injectors we just ordered a 95 vr4 harness and ecu as far as internals it's a fresh motor with Ross pistons from ninja performance timing is there compression and fuel and spark now were going to try cam sensor and crank and getting rid of the cas
And no it's a vr4 ecu out of a 92
OK right now it's an NA harness with a 92 TT ecu? There is some modifications that need to be done for the NA harness. Hopefully the new harness and ECU will do it. Make sure you are getting a resistor pack and rear injector harness also.
