Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Help!!!!!!
    Exclamation Help!!!!!!
    i have a 92 3000gt sl that i built a motor for with all forged internals and did the tt conversion got it all together and when you start her she revs to about 2500 3000 rpm range one time then quits then wont even sputter after that unless u let it sit for a few min ....... has spark fuel pressure at 57 psi has injector pulse timing is correct and wont even sputter off starting fluid tried diff ecu's same thing running out of ideas pls help reply to this or email me goes straight to my phone any thing is appreciated rexaaa6847@gmail.com
    Newark, DE
    Fuel pressure should be 43psi. Your fuel regulator hooked up to intake manifold nipple? If you can confirm ECU is okay check sensors per fuel system section in manual.
    91 AWD TT
    engine will run if you have
    1)spark:cam/kranc sensors,coils,igniter,plugs etc...
    2)fuel:most of input sensors,fuel pump,injectors etc...
    3)compression:valve timing,engine mechanical etc...
    Obviously you missing something,must find affected circuit...may be you losing spark or fuel during cranking or may be you never had valve timing right to begin with or made mistake putting engine together.
    Recheck timing -use this link as a guide,you will see timing marks very clearly,1994 3000GT VR-4: Engine Pictures
    You will need some kind of scanner/data logger,so you can see sensors outputs to ECU and ECU outputs to control units like IAC
    Any updates?
    Real drivers don't use speed limits verified
    Buffalo, New York
    I've looked at this car once to try to help him out and I am going to continue to help him try to figure it out. Unfortunately I have never done the TT swap so I told him to post on here for other people that have done the swap to give some input. The vacuum is all set up right, fuel pressure cannot be set unless the car is running, it would still start otherwise with that fuel pressure. When I saw it, it started for about 2 secs, then just wouldn't start anymore. It has spark and def has fuel, the timing I have no idea about, but he says everything is lined up. He does not have a TT harness for it, but he ordered one. Rex, isn't the block weird or something with it being like a 93 block, but you set it up so it has CAS in one?
    Oct 2011
    Brisbane, Australia
    I'd check the MAF is plugging in properly, the CAS is working and that theres no massive intake leaks. Doesn't sound like timing if it starts, dies then starts after sitting for a big. As its easy, pull the ecu and check the caps too
    You can sort of set the fuel pressure by running the pump without the engine going. Its not soaking the plugs on start?
    Buffalo, New York
    Pressure wouldn't really cause it to do that, I could see if the pressure was dropping out. I wish I had an oscilloscope though, would make everything so much easier.
    Buffalo, New York
    A maf wouldn't make it do this also because it would still start up then die out every time.
    Newark, DE
    Quote Originally Posted by Woz View Post
    My understanding is u can't rule out maf except by substituting known good one.
    connected via tapatalk
    Apr 2011
    buffalo NY
    Yeah it is a 95 block with 91 heads on it the timing is perfect we just ordered a 95 harness and ecu to Try using cam and crank sensors
    1991 3kgt sl, all forged internals, 450cc injectors, 13t's, eBay turbo back, walbro 255, hks ssqv bov,turbo smart mbc, 3sx fuel loop, 3sx polly mounts, 3sx dual core rad, FMIC, 99 big bore lifters, xtd stage 3 clutch
