Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 43
Thread: Normal EGT reading
  1. #31
    Never finishes any verified
    Wake Forest, NC
    you're kidding, right?
    I think he is referring to my statements about the high EGT and causing damage.
    I retract my previous statements as I found that my initial findings that aluminum melts at 1200F were way wrong do to me only reading specific sections online and not the whole statement.
    Even with my statements being wrong in some aspects, there is still a lot of good learning information in this thread regardless of the impertinent comment made.
    Update:
    Pulled the Stealth out this last weekend I made sure to pay attention to my EGT.
    Found that 80mph cruise I was at about 950-1000f when cruising.
    WOT pull was around 1300f till the water/meth kicked in then back down to around 1200f
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  2. #32
    i was half-joking. if you are running consistent 1000C temps in pre-turbo EGT, you are running a very real danger of catastrophic turbo failure, imho.
    if you're running 1000C AFTER turbo EGT....you might want to keep a fire extinguisher handy at all times.
    p.s.
    steel loses 50% structural rigidity above 1200F. keep that in mind.
  3. #33
    yeah I didn't think anyone would believe the catback to be nearly as hot as the manifold pre-turbo.
  4. #34
    SDSU Alumnus verified
    Nov 2006
    Chula Vista SD, CA
    How about the STS turbo kits? You made me think about them lol.
    Here are examples for those who are clueless or unaware:
  5. #35
    What is this based on?
  6. #36
    from stealth 316:
    At WOT, values between 850ºC (1562ºF) and 900ºC (1652ºF) are often considered ideal; temperatures below 800ºC (1472ºF) are considered too rich; temperatures above 925ºC (1697ºF) and approaching 1000ºC (1832ºF) are considered dangerously lean and can result in excessive engine detonation (knock) and possibly burnt or melted components (valves, spark plugs, pistons, rings).
  7. #37
    Peak EGT's are of no use for tuning. Hint: Aircraft recip engine EGT gauges usually don't even have numbers on them. I'd post more, but I'm already getting chatbox withdrawl...
  8. #38
    Banned J. Fast's Avatar
    I agree peak EGT's are somewhat insignificant because you're generally well beyond peak power and peak cylinder head pressure. EGT's are important though, and they can be a tremendous aid in real world perfomance. EGT's can be used for peak horsepower allusion. Lock into a cell on the dyno (using the eddy brake) and tune the cell to maximum brake torque and index the AFR/EGT for future reference. Do the same with WOT pulls (take the engine to MBT).
    Once off the dyno you can tune real time with all the elements that a cube with stagnant air can't produce such as aero, drag, system interference, and etc. You fine tune at the track based off the dyno collected information of what EGR/AFR combination produced maximum brake torque and you adjust for real world conditions knowing that "X" AFR at "Y" EGT produces maximum brake torque with "Z" degrees of timing. Those are all knowns and shouldn't change the peak performance MBT number regardless of altitude or temperature.
    Cool thread idea Alan. It'd be pretty cool if someone compiled all this data and built a known MBT to AFR curve for the different compression ratios and adders. I think the trend curve would be interesting to evaluate.
  9. #39
    from stealth 316:
    Yeah, I don't know what his source was, but Banks says that you should never exceed 1400 F (760 C), so I just have a hard time buying any of these ultra conservative published recommended values.
    What are the high power Supras running? DSM's?
  10. #40
    Diesels use EGT for another purpose. They use the pre-turbo EGT as an indicator of chamber temps (and as an indirect measure of piston surface temp, which is what you're worried about). With stock setup it's recommended to stay below 1200-1400*F, or in the case of the 7.3L it's recommended 1100 over 5 minutes, to prevent piston/rod failure. With aftermarket pistons/rods that recommendation no longer applies, as in pulling and drag racing you'll see over 2000*F regularly. There is another issue, in that you melt the turbine wheel after a while. Turbos are a consumable to us at that level, and we install cross bolts in the downpipe to catch the turbine as it leaves to keep it from shooting out the pipe and hurting people. The typically cooler EGT's of diesel combustion is why they've had VNT/VGT turbo technology for years in OEM applications, while just recently it's been possible to reliably install them in gas engines. Back to gas engines.
    The recommended "950*C" roof came about because the chances of turbine failure rate increases greatly beyond that. That was before Inconel, monel, and titanium alumide turbines, but the recommendation stuck. For intermittent operation I see no harm in passing that mark as far as the turbine is concerned. Back to chatbox...
  11. The Following User Says Thank You to anyonebutme For This Useful Post:
    IPD
