Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 104
Thread: FMIC Picture Thread
    I'm Kind Of A Big Deal
    Quote Originally Posted by Boomer3000 View Post
    How was the install on the cx racing one? also were the welds up to par?
    We have installed dozens of the CX kits, fits, functions, and looks great. Easy install, if you take your time, do a loose-fit, then tighten it all up. perfect fitment every single time.
    We polished the piping (and end tanks) from the CX Racing kit, and they look absolutely amazing
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
    GREASE BUNNY
    VA
    DEJON setup...Dam I miss my car.
    not sure what kit it is, made from steel tubing.
    Quote Originally Posted by TT Eric View Post
    Eric
    DR750's + blacked out IC...
    i agree with emilie, the CX racing kit works really well. the only 'issue' i ran into was because i was using the subi 13t compressor cover. its got a straight outlet instead of the curved outlet like on the stock turbos. the difference in the angle of the outlets caused my piping to have ~6" gap. but that was solved with a bit of marine boat exhaust turbing. high pressure and high heat rubber reinforced with 1/16" steel rings molded into the rubber. so far its held without popping off once in the past 2 years.
    this pic shows the difference between the mitsu cover and the subi cover.
    the basic go fast bits...
    Tuned by Ray Pampena
    Just a fun Daily Driver.
    The Panda Not Verified
    Washougal WA/Portland OR
    Eric
    Here's a custom one off ETS intercooler kit made 100% by ETS to fit my IPS EVOIII setup.
    At ETS's shop for custom fitting, still adjusting location of pipes and IC core.
    Finished product bling under hood and stealth up front.
    My Truck is Faster Than My Car
    Lander, Wyoming
    The only thing about ETS I don't like is the piping directly on the driver's side of the core. I think it would look really weird on a first gen 3000GT
    Levi
    '92 3000GT VR4
    16T's, 550cc, SAFCII, Coilovers, etc
    2004 GMC CC/SB Duramax LLY - Built Motor, Built Trans, 80% overs, S483 over 72vgt, nitrous
    The Garage Queen/Show car - 1969 Ford Mustang Mach 1
    TTeric uses a ets kit. The reason I don care is because I blacked out my pipes to hide. If you want polished then that's different.
  8. #18
    Wrench Monkey Not Verified
    Rochester, NY
  9. #19
    Very nice vr4tune! you too Eric!
    I like this thread
    Easton
    First start up after the new core earlier this year
