Results 1 to 7 of 7
Thread: Shift boot $22 shipped or Shift boot + ebrake boot $30 shipped
    I'm offering quality top stitched OEM like shift boots and ebrake boots for $30 shipping included. The shift boot can be purchased separate for $22 shipping included. Colors available are black, charcoal gray (lighter than the original), mist gray, royal blue, red, white and tan. Charcoal gray is a shade lighter than the factory charcoal gray found on our cars. Most people choose black as it looks better.
    In the paypal comment section please indicate which color you'd like.
    Paypal: blacklight99 @ gmail.com
    installation instructions for ebrake boot
    Shift boot installation:
    1. Rotate the shift knob counter clock wise and separate.
    2. My two fingers in the picture are pointing at where the plastic clips are located. Apply pressure there to separate base from car.
    3. In this picture you can see the plastic clips more clearly. The opposite side also has the same plastic clips.
    4. With the shift boot inverted you can see the factory zip tie, cut the zip tie and separate the rubber shift piece.
    5. Install your new shift boot.
    St.Louis
    I need a black with red stitching shift + brake boot combo. Will send money tomorrow my phone dosnt like paypal.
    Bump, still available.
    Bump.
    Bump for a good product. Mine still looks great almost 2 years later.
    I might have to do this. Great price!
