Results 1 to 10 of 10
Thread: Original IPO dual walbro fuel system (tank to rails)
    Huh? verified
    Detroit Area, MI
    I have a used IPO dual walbro fuel system setup. Included is pretty much everything except a pair of walbro fuel pumps and the -6an fittings for the end of the fuel rails (most aftermarket rails come with these though). Specifically what is included:
    fuel pump sender assembly with -6an bulkhead fittings
    dual -6an lines to a "y" fitting
    -8an line to the front of the car
    large high flow -8an SX in-line fuel filter that can fit in the OEM fuel filter bracket location
    -8an to dual -6an lines to the fuel rails
    dual -6an lines to the fuel regulator
    aeromotive 13109 fuel pressure regulator with fuel pressure gauge port
    -6an fuel line from the regulator to the factory fuel supply line
    -6an adapter fitting for the factory fuel supply line
    Not included:
    Fuel pumps/wiring, -6an fittings for each fuel rail end, a fuel pressure gauge, and a ~ 6" piece of fuel hose/clamps to connect the factory fuel supply line to the fuel tank return line
    The fuel pump sender assembly is crap (I stripped it of some wiring) but the bulkhead fittings are still installed so you can exactly transfer them over to yours in the proper locations. Everything is in good working condition but is obviously used.
    Asking $375/shipped for everything without the fuel pressure regulator/fittings (in case you have your own) or $500/shipped with aeromotive regulator/-6an fittings. Any questions just ask...
    1993 3ooogt vr4
    Big single turbo and every other mod...
    Powered by BorgWarner
    VR-3747 :D Not Verified
    Dayton Ohio
    im really interested, just not sure if i want to spend that much on it right yet.
    hmmm ill get back to you
    I AM IMPORT POWER
    Driving Vicki Crazy
    Wow, I made that a long time ago. Good to see it's still 100% intact and working!
    Good price on it!
    -Chris
    Huh? verified
    Detroit Area, MI
    Yeah I bought it like-new from a 3si member (tallskinyguy I think) about 7 years ago. I ran it on my car for a couple years (few actual miles) until I decided to change up my fuel system a few years ago. Its a good proven design I just don't need it taking up space in a box.
    How much better fuel flow do you think this will give you and benefit's ?
    Huh? verified
    Detroit Area, MI
    Quote Originally Posted by GGstealth714 View Post
    Compared to stock? This setup is easily good for 700++ awhp with a pair of decent pumps.
    Bump...
    I AM IMPORT POWER
    Driving Vicki Crazy
    Quote Originally Posted by Boostaddict View Post
    Bump...
    Well over 1000AWHP actually.
    -Chris
    Crazy no one has bought this so I guess I will. Whats your paypal address?
    Current:
    1972 Chevy Nova
    2004 Ford F350 Lariat 6.0L
    1991 Stealth TT FWD
    1962 Volkswagen Beetle
    Previous:
    1994 Stealth RT/TT
    1999 3000gt SL
    1973 Volkswagen Super Beetle
    1976 Jaguar XJ6
    1991 Chevy S10
    2000 Ford focus
    Huh? verified
    Detroit Area, MI
    Money sent for everything sans the pressure regulator.
