look on the "bolt" part of it. there is a spot to put on a wrench to hold it still while you turn the nut. a 10mm wrench if i remember correctly
ok? probably. just dont push the car very quickly. if there was a way to keep them off the ground that would be best. truthfully, the best solution is to take the axle boot apart and just have the end of the axle bolted onto the hub so you can keep that bearing in check as well as not have flopping axles. but that is extra work to do all that tooAlso, it was pointed out to me that the axles will be hanging loose since they connect through the tranny.. Will it be okay for sure to push my car on tires with the axles not connected to each other?!
