I'd personally go with Maximal's camber arms with the heavy duty ends: Suspension - AWD Adjustable Control Arms - Maximal Performance
FWIW, my VR4 was barely within spec on camber and I was at stock height as well so I guess it's not too rare.
I'd get them to aim for at least -1 degree camber on the front, and maybe -0.5 degree on the back. Those settings seemed to work well for my VR-4 in DD duties. Spirited driving requires more camber.
a little negative camber never hurt anyone, as long as you can get each axle set to have about equal camber with its wheel partner and keep it around 1.25 or below negative you'll be fine.
Personally I'd stick with the stock rear arms as long as you can. I have aftermarket arms and I don't care what kind you get, rod ends wear a lot faster than stock ball joints or bushings.
Rod ends without using dust shields are made for race cars that get taken apart very often.
