Results 11 to 20 of 24
Thread: in need of bearing stay caps.
    Twin Turbo verified
    Melbourne, Australia
    Maybe you have an NA block? especially since it's not the origional motor.
    Waiting install
    Build Thread
    It could be.... But it has a forged crank in it. Either way I want to put then back in for the rebuild.
    Sent from the bat cave
    1991 Stealth RT/TT forged crank, new pistons/bearings/rings, T16's ceramic coated, precat deletes ceramic coated, full exhaust, FMIC, Dijon intake pips, adjustable cam gears.
    Banned J. Fast's Avatar
    Pictures make sense now. Check with GZP for those. I'd bet he or Emily could dig some used ones up for you.
    Ok thanks. But ummmmm.... Who are they?
    Quote Originally Posted by smoking rr View Post
    Ground Zero Performance. They're a supporting vendor on the forum homepage. Just post in their "Used Parts " thread. They will usually answer back in a hour or so with pricing. GZP is a good vendor on this board, as are all the supporting vendors.
    Ok thanks. I will give them a try.
    I AM IMPORT POWER
    Driving Vicki Crazy
    NA blocks were always 2 bolts and never had Bearing cap stays.
    Although the NA's did go to forged cranks in 93 just like the TT, but the TT went to 4 bolt in 93 also.
    If I remember correctly, the Bearing cap stay are no longer an available item from mitsu.
    -Chris
  8. #18
    Well as you can see my block is missing them so I figured it was a tt block.
  9. #19
    I AM IMPORT POWER
    Driving Vicki Crazy
    Yes, it is a TT block.
    -Chris
  10. #20
    I have a spare block, but its going to be hard for me to part with just the stays. I'd guess they are machined to fit the block and it may not be best to mix and match them.
