Page 17 of 19 FirstFirst ... 71516171819 LastLast
Results 161 to 170 of 190
Thread: The Useless Banter Thread
  1. #161
    Twin Turbo verified
    Melbourne, Australia
    1 inch on each end for end tanks isn't enough as you need to weld on a pipe of at least 2-2.5" on each one. So unless your going to mount the hose/pipe some weird angle then you need bugger end tanks. Which means smaller cores.......
    Waiting install
    Build Thread
  2. #162
    I'm taking them one cooler at a side, only doing the drivers side at the moment but yes it will have weird angled inlet see below picture which will have to be roughly they correct design for both of the bottom of both coolers (one will be angled to go into the side of the car, the other one for the pass will be angled to go back up through the top of the guard.
    note how it quite litterally adds less than 1 inch to the total core length.
    and the top of each will be roughly:
    there is actually room to make it even better than this but you get the drift.
    1996 GTO, Owner since 2003.
  3. #163
    Twin Turbo verified
    Ahh cool. Just try to design the end tanks well, so if flows the air through the whole core. The end tank on the bottom pic is a terrible design. Sometimes it's the only option due to space etc. What you can do is install fins that channel the air through the core better.
  4. #164
    No worries
    planning on pretty much using a hard lead or soft aluminium to mould it into being juuuust right, and then re-brazing it when I'm happy over the top...
    maybe even make a metal frame and braze over that, according to a lot of sites it was (again from vague memory) the inlet that's the most important, the exhaust they said could be a bit more squished(good work that one) and still perform well.
    anyway given a few weeks and we'll see how we go! quite excited actually working on making more power for once!
  5. #165
    Twin Turbo verified
    Never played with aluminium braizing, only copper. TBH I never knew there was such a thing LOL. Making end tanks shouldn't really be hard. Just takes time and patience to bend/form it to the right shape. Good luck.
  6. #166
    Twin Turbo verified
    So hopefully I will be buying these off Anne on gtoperformance very shortly
  7. #167
    ooOOOo very Phat
  8. #168
    Twin Turbo verified
    Direct bolt on with about double the volume [or more] for only NZD$350.00 WOO HOO She just emailed to advise they are mine so now just waiting on a postage quote.
  9. #169
    got any specs on them?
  10. #170
    Intercooler Kits 3000GT VR4 90-99 (2 Cores) 200mm x 216mm x 65mm
    Each HKS Intercooler kit utilizes an application specific tube and fin intercooler core with cast aluminum endtanks, as well as mandrel bent intercooler pipes...
    Show More
