Carbotechs are pretty dang good. I have xp8's for the rear but they screeeeech! I put them on for only track days.
Sent from my SM-G900V using Tapatalk
3SNG15 Best overall
Runs 12's (12.98's!!!!!!)
My Garage
After 6 years of track use my floating 355 mm rotors are looking pretty worn and the thickness is down to less than 30,5 mm.
Does anyone know if these discs match any of those sold by AP racing or other brands? I'm having a hard time finding anyone who sells XYZ rotors separately.
Try contacting them directly: http://www.xyz-racing.com/contact.php#Main
I can't even find my old emails from the GB so I don't have a way to contact the dealer we used for the GB or the replacement rotor prices I was given. I should have bought some extra kits and rotors back then but I figured (correctly it turns out )I'd never need them, lol.
I remember wilwood having rotors that seemed close, but I never measured to see if they would work.
Thanks for a quick reply. I've sent them an e-mail. The Swedish XYZ dealer that I bought the kit from is no longer around and fore some reason very few stores seem to sell these kits these days.
I'll let you know when I've found a set of compatible rotors.
I did some measurements and I think the discs has center bolt pattern of 12x115,9 and they use M6 bolts for attaching the disc to the aluminum hub.
So these discs should fit, but I'm waiting for a final confirmation:
https://www.mtecbrakes.com/2-piece-b...6-32-1004.html
This was my backup plan, but doesn't help you in Europe:
http://www.colemanracing.com/Heavy-D...nes-P6401.aspx
Custom made rotors, they have 2 versions, this one is a lighter one with larger vents, then they have one with smaller vents and thicker friction surfaces. Pic says 13.1" max, but it's actually 14".
That company you posted has them on ebay as well, I figure I'll send them a message to see what shipping to US is.
