can i get a matching set of rear brakes? say a matching set of 330's?
does the ksport front bias really matter if it's paired with ksport rear brakes?
how much additional cost for other color options?
I don't know what size pistons are used in either the xyz or ksport rear kits, so I can't calculate the bias when using the 4 wheel kit.
The color option is something like $100-$140 per axle. If you're serious about this I will get all the info and calculate the bias and rear kit costs (historically they are about a hundred more than the fronts).
wtf? rear costs more than front?![]()
Parking brake hat.
ah. yeah. that thing i never use.![]()
I have templates, PM me and I'll send PDF, but the info above still counts.
Chris...great work pulling this all together!
Please PM or email over a template to see if they'll work with my rims.
Thanks!
Pete,
I measured my 5zigen fn01r-c 17x9 wheels with +35 offset... the ID at the hub is almost exactly 15.75" and it tapers larger closer to the wheel well. Since your offset is even more extreme I'd think you'd be okay (might be tight tho). My wheels would be really really close tho (not that I have $ for brakes).
1993 3ooogt vr4
Big single turbo and every other mod...
Powered by BorgWarner
