OK, trying to get a couple more people in this to lower the cost for everyone. This will only be open to the "public" for a very short time, as I'm ordering brakes like right meow.
Group Buy for 6 piston forged caliper front brake kit, XYZ branded. Complete with 355x32mm full floating rotors, float-in-hat style. Standard colors are black anodized, red or yellow powdercoat. Comes with SS brake lines, and rear 4 piston kit is available. You'll notice I didn't specify a car, that's because if you want to buy a kit for say, a Corvette, go ahead and jump on, though I won't provide technical support or information for that stuff. Pricing may vary.
Pictures as fitted onto Z06 race car during testing, Corvette specific kit:
Black caliper pic:
Floating rotor hardware:
Now, down to technical business before I get to pricing:
XYZ kit piston area: 2415 for 355mm rotor
Stock piston area: 2721 for 314mm rotor
Stoptech piston area: 2274 for 355mm rotor
AP Racing "formula" kit piston area: 2511 for 343mm and 355mm rotor
K-sport 8 piston kit piston area: 3059 for 356mm rotor
I'll save you the calculation for brake torque split, (difference from stock, + is more front torque than stock) corrected for rotor size, and just post them:
Stock: 100%
XYZ 355 on 2G: +1.81%
Stoptech 355 on 2G: -3.37%
Stoptech 355 on 1G: -0.41%
AP racing 343 on 2G: +0.73%
K-sport 356 on 2G: +25.48% (ummmm)
So, what does this all mean? XYZ 355 kit will be slightly more front biased than stock, as I spec'ed to correct for typical track car's new weight distribution and increase in weight transfer on sticky tires. That and K-sports are wayyyyy out there in balance.
Sooooo, if you're still reading, I got your attention still, but before we get to pricing there's more technoblabble to get though for those who care.
Why floating rotors?
[straight from AP Racing]
Radial float allows differential expansion of disc and bell thus reducing stresses in the disc and minimising disc cracking and distortion.
The idea of axial float is to compensate for a certain amount of stub axle / upright flex by allowing the disc to take up its ideal position within the range of float thus avoiding "knockback" of the caliper pistons. Knockback requires you to pump the brakes before entering a corner to achieve maximum braking effort.
OK, still with me? Now what you were all waiting for: Pricing. Normal pricing is a tad over $2K for this specific kit.
3 kits: $1650 per 355mm kit shipped
5 kits: $1580 per 355mm kit shipped
Pricing drops per every kit.
Now, kit options.
Powdercoated red, yellow or anodized gold, black are our caliper standard colors. Painted gray, gold, blue or any other painted colors to match your vehicle are available as well; however, it requires additional cost.
Non-floating rotor option available for slighly less cost.
330mm Kits are available for those seeking to keep 17" wheels (at reduced cost), although braking torque split will be effected.
Kits will come with generic "street" pads, though I highly recommend getting a set of Carbotech pads in choice of compound because I heart Carbotech pads. Street pad info: Coefficient of friction: .46 - .53. Temp range - 194 - 1,022. Pad shape for Carbotech pads is CTP7790. Everybody makes their compounds in this shape.
Standard motorsports disclaimer goes here.
