Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 93
Thread: Deleted my oil cooler.
  1. #81
    Banned J. Fast's Avatar
    Quote Originally Posted by AudibleSilence View Post
    Interesting, though to your point I've never seen that measurement on any industry standard TDS. Most companies break it down to VI and give you the sheer #s if that. What would said information tell you (personally) that the VI @ temp X doesn't in relation to what is best for your car at a motorsport event?? Most of the engineers that I deal with seem to be good to go with info readily available? -listens intently-
    Does your company use this model?
    Applied tribology: bearing design ... - Michael M. Khonsari, E. Richard Booser - Google Books
    Is table 2.4 Correct?
  2. #82
    The Infamous Mr. Chocolate
    D Fawkin' W
    My company does the HTHS testing (viscosity at certain temp/pressure) yes... I wasn't paying attention to what the test actually was, I just knew what we called the resulting info, my mistake. Mobil does, we do..not sure about Shell...I have never had a customer ask me about the HTHS spec, 90% of the time they just want to know the operating temps. . As I understand it, this info is useful in motorsport for things like picking the right viscosity/oil for a things like piston rings and such. I've never heard of it being used as such, but that's what I gather. Pete can you clarify?
    Current Car:
    2011 Chevrolet Corvette GrandSport
    Cars Owned:
    1992 Dodge Stealth RT (sold)
    1992 Mitsubishi 3000GT VR4 #1 (parted)
    1992 Mitsubishi 3000GT VR4 #2 (sold)
    1993 Mitsubishi 3000GT VR4 #1 (KIA)
    1993 Mitsubishi 3000GT VR4 #2 (sold)
    1994 Mitsubishi 3000GT VR4 (sold)
    1994 Mitsubishi 3000GT Base - awd/atx (sold)
    1997 Mitsubishi 3000gt VR4 (sold)
    2006 Pontiac GTO (sold/traded)
    2008 Chevrolet Corvette 3LT (z51)
  3. #83
    Runs on alcohol. The car does too. Not Verified
    San Francisco, CA
    This ended up being one of the most interesting threads on 3sgto in a while. What can I delete next?
    AEM s2 EMS | E316Gs | E85
  4. The Following User Says Thank You to Intropy For This Useful Post:
  5. #84
    STL, MO
    put Potatos in it.. it cools it down so well..
    1991 Stealth RT/TT
  6. #85
    SKADOOSH!!! verified
    Prince George
    What method did you use to delete yours? I deleted mind the other day, but completely overlooked the fact that I can't just simply plug the holes. I was thinking that I could cut the banjo ends off of the stock cooler, flair the opening and loop them. Does this seem like something that could be a good temporary solution until I get my N/A filter housing here??
    Photobucket
  7. #86
    San Francisco, CA
    Well, to be fair, I added a new oil cooler, this was mostly fun / flamebait. But when it was leaking, I installed AN adapters into the filter housing and looped a short piece of -10AN hose.
  8. #87
    Quote Originally Posted by Intropy View Post
    You know you could have got 25 years for that in Arizona.
    stow
    i douth you have anything to worry about deleting the oil cooler. the first thing iam doing to the gm l99 ls engine iam putting in mikes 1970 gto is to delete the oil cooler. the reason the 2011 camaro ss uses one is the engine is highly confined . all folks who are using the l99 and ls3 are also deleting the oil cooler. if iwas worried about it i would get one of the bigger oil pans i see for the 3s .. some car forumns have a bunch of factory emgineers on board that would have a answer but i dont think anyone here would know for sure since our cars are so old. do we have any mitsu engineers on our forumn???
  10. #89
    Prince George
    I actually just bit the bullet and bought some fittings after work, so I did the same, it works quite well ...And there's no more ugly leaking cooler hanging off the side of my car!
  11. #90
    An excellent 10 Chapter Read: >>> Motor Oil University - Bob is the Oil Guy <<<
    Quote Originally Posted by AE Haas,
    Motor Oil University, Bob is The Oil Guy Chapter Five – Let’s use top gear.
    Let’s go racing. I will discuss driving in traffic jams in the Florida summer as well as racing in Sebring though there is no commonality. People lump these two driving situations together but there is no overlap.
    On the race track one usually uses all the BHP their engine can give them. You briefly step on the brakes for the corner then put the pedal to the metal the rest of the time. Your oil will get up to 302°F, but your cooling system is around 212°F. The engine produces tremendous heat but can only pass it off so fast to the cooling system. There is a lot of air moving past the cooling radiator so the antifreeze / coolant is able to get rid of the extra heat from this part of the system with relative ease.
    The temperature of oil on your gauge is not as hot as it really gets. This temperature is an average with oil from different parts of the motor. Some parts are hotter than others. It is said that some of the oil gets as hot as 400° or 500°F in these racing situations.
    In an earlier section I said that thicker oils are usually needed in racing situations but not necessarily. Remember that a major function of oil is to cool the inside of your engine. In ASTM D 4485 3.1.4: “Terminology: Engine oil- a liquid that reduces friction and wear between moving parts within an engine, and also serves as a coolant.” Since the oil with a viscosity of 10 cS at 212°F thins to a viscosity of 3 cS at 302°F we will get more flow. The pressure will go down some as well. This is OK as long as we have a minimum of pressure to move the oil.
    This increased flow will result in increased cooling by the oil. This is a good thing. You would probably want more oil flow in these situations and you get it. The hotter oil thins and this increases flow. The higher flow works harder to separate the engine parts that are under very high stress. It all works out for the better. Higher revving engines need thinner oils. You do not necessarily need to go to a thicker oil while racing. Only experimentation will tell.
    The best way to figure out what viscosity of oil you need is to drive the car in the conditions you will use. Then use the oil viscosity that gives you 10 PSI per 1,000 RPM under those circumstances. For some reason very few people are able to get this simple principal correct. I cannot explain further.
    These same rules apply to engines of any age, loose or tight. Just because your engine is old does not mean it needs a thicker oil. It will need a thicker oil only if it is overly worn, whether new or old. Yet the same principals of 10 PSI per 1,000 RPM still apply. In all cases you need to try different grade oils and see what happens. Then choose the correct viscosity.
    I used 0W-20 in my Ferrari 575 Maranello. It had over 5,000 miles on the clock. There will be a day (my estimate is 50,000 miles) when one will have to go to a 0W-30. In the future one will have to increase the viscosity to a 0W-40, then a 0W-50, maybe. You should use whatever it takes to get 75 PSI at 6,000 RPM during the lifetime of the engine. This formula works in all situations.
    Some people have tried this and occasionally get a somewhat low oil pressure while at idle. This is fine. There is no stress on parts at idle, the smallest oil flow will do the trick. It is at higher RPM where more BHP is produced. This is where we need the flow. Remember that Ferrari uses 75 PSI at 6,000 RPM as the place to test your oil viscosity needs. If your oil gives this value under your driving conditions then your lubrication system has been maximized. Period.
    Do not go 5,000 miles with the same oil if you are racing your car. You should change the oil every 1 or 2,000 miles. If you drive your car around town then you need to change the oil for that situation. Use racing oil on the track and urban oil around town. The best situation as described by Ferrari is to use the 0W-40 around town and the 10W-60 “racing oil” on the track. It has to be that “hot” track though. A compromise situation would be to use the 5W-40 for both but this may not be optimal. Certainly, if you are just an urban driver as me use the 0W-40 or even a thinner oil as I do in my Maranello. Again, I used the 0W-20 grade.
    FYI. The Formula 1 cars that run at 15,000 RPM and higher use straight 5 and 10 grade oils.
    Now let me discuss what people think is a similar situation to racing. That is hot summer traffic jam driving. Your car should be able to handle this. If you have problems then you have a problem with your car, most likely in need of a cooling system overhaul.
    When you drive that car down the road mid-winter in upstate New York or mid-summer in Florida the engine and oil temperatures will be around 212°F. But your Florida vacation is suddenly altered by a hurricane. You have to get out of Tampa, but so do a million other people. It is now 95°F and you are in a snarl. Everyone thinks they need a thicker oil for this situation. This is false.
    Your engine is not producing much heat at low RPM and low BHP output. The production of heat is relatively slow. It can easily be transmitted to your cooling system. The problem is that your cooling system has trouble getting rid of the heat. The oil and the coolant will slowly rise in temperature. They both rise together. The increase is no big deal for your oil. It goes to 220°, then 230°F. The problem is that the cooling system can only handle heat up to 230°F. After that you overheat the cooling system and the car must be shut off. The oil never got that hot, It was just that the water got a little hotter than its system design.
    You now see that overheating in traffic is a cooling system problem and not an oil system problem. Do not change to a thicker oil based on your traffic situation.
    That pretty much summed up why an oil cooler isn't necc for a BHP DD car. 0w-50 produces 75 psi at 500 degrees and it doesn't burn. I dont think you can get oil that hot by driving to the grocery store. Likewise, I don't think you could get it over that temp on the track and risk spinning a bearing or damaging turbos or journals before you overheat or pop the headgasket. Even though the thread was a sham and quite silly, learning what I have from the racing community and BITOG, I pretty much think you could delete the oil cooler if using full syntheic oil vs. mineral based oil and see no ill effects.
