1 cheap ass ebay core will do the job like this http://cgi.ebay.com/ebaymotors/UNIVE...ht_2770wt_1165
2 Adapters For Oil Cooler if necessary -10 AN Female To -8 AN Male in this case
2 -8AN 45-90-degree Hose Ends fittings near the oil filter
2 -8AN 0-90 degree Hose Ends fittings at the cooler.
of -8AN Hose 7 feet or less if sidemount
2 -8AN to M16x1.5 Metric Adapters into the holes in the oil filter housing
2 M16 Crush Washers (Copper or Aluminum)
or just buy the hose assembled ie
http://cgi.ebay.com/ebaymotors/NEW-8...#ht_3453wt_939
ebay for cheap parts
http://cgi.ebay.com/ebaymotors/10-Fe...#ht_1193wt_939
http://cgi.ebay.com/ebaymotors/Black...d#ht_500wt_956
http://cgi.ebay.com/ebaymotors/8-Bra...#ht_1384wt_939
http://cgi.ebay.com/ebaymotors/?cmd=...#ht_2141wt_939
http://cgi.ebay.com/ebaymotors/CW901...#ht_2573wt_939
you can buy good quality stuff from ebay too like this and its relatively cheap way cheaper than OEM
NEW Fluidyne AN8 Engine Oil Cooler 11x8x2 | eBay
Good posts!
-Chris
thanks
you can make yourself an equivalent kit to this using the ebay core for less than 180$ but you must hunt for cheap parts
3SX Oil Cooler Kit - Core + Lines + Fittings - FMOC*-*Mitsubishi 3000GT*/*Dodge Stealth Parts
I like what Trevor did with his, I'm just waiting for my excuse!
yeah dual ftw. but I like my big ass single front mount better way simpler and cheaper solution I didn't even have to make a bracket to hold it + oem shrouding fits .Overall install was a breeze
with the oem cooler I could see temps as high as 140C even more during very hard driving .
I havenīt seen temps exceed 110c with this one, not a surprise it is about 8+ times bigger than the oem one!
Since we're talking on the cheap... Just FYI, CX Racing sells 30 rows with with 10-AN inlet/outlet and (2) 5' 10-AN PTFE hoses for $145. Core dimension is 11" x 9" x 2".
They also sell several variations of aluminum 10-AN cores for under $75 shipped.
# Rows = Core Size / Overall Size
30 row = 11" x 9" x 2" / 13" x 9" x 2"
28 row = 11" x 8.5" x 2 / 13" x 8.5" x 2"
25 row = 11" x 8" x 2" / 13" x 8" x 2"
Lastly CX also sells billet oil filter sandwich plates with oil temp and oil pressure sending unit tap ports for dedicated gauges. I paid $75 for one.
Pretty inexpensive options.
yep and keep your eyes open too there are plenty of nice "nascar"etc cores for sale on ebay from time to time.
like this one of mine its a fluidyne cooler ~12"x~12"x~3" 12-AN I think I paid 280$ for it
Good posts guys!
The only thing that scares me a little about aftermarket oil coolers is I would want to make sure it flows > = to the stock one. You can spin a bearing in one of these cars with a shitty oil filter cutting off flow so I've been a bit hesitant to go with one without investigating them a bit more. I've also wanted to do a remote oil filter with a bigger filter. There seems to be plenty of large remote oil filter kits that use a big V8 domestic oil filter that would work nicely.
