Results 1 to 10 of 22
Thread: Misc Used OEM Parts
    Misc Used OEM Parts
    Parts are from a 94 3000gt VR4, some american, some japanese. I take paypal only, and prices are only good for the US. Click on images to be taken to a larger one.
    Shipping will be through USPS Priority mail or first class depending on weight. Over 50 dollars will be insured. Parts are sold as is.
    Stock BOV, the one with out the vac line. Diaphram just tested, no leaks.
    --20 shipped each
    Thermostat junction block with sensors.
    -- 50 shipped
    J-spec "pre-cats" - Rear has no cat material, NO O2 Bungs
    --70 shipped
    Power steering pump, worked fine when removed, pulley has surface rust.
    --45 shipped
    J-spec 2G starter - Not tested, Rest of the motor was in good shape though
    --50 shipped
    SOLD:
    J-Spec coil pack set
    J-Spec Injector resistor pack
    Crank angle sensor
    Cam angle sensor
    Set of stock wastegate actuators
    BOV with vac line
    J -spec PTU - Used it for a month no problems, can include bracket if needed
    --50 shipped
    Power steering tensioner - Has surface rust on pulley, pulley spins freely
    --25 shipped
    Rheostat assembly - worked fine when removed
    --25 shipped
    Stock FPR - Worked fine when removed - Diaphragm has no leaks
    --15 shipped
    Set of 2G turbo manifolds - Tubular one is cracked 3/4 of the way around - Will include support bracket in pic
    --45 shipped
    Stock fuel rail loop
    --10 shipped
    SOLD:
    J-spec 360 injectors
    Engine Damper
    3sx EGR block off plates
    Bubble and intake pipes - Need a cleaning
    --50 shipped
    Oil dipstick and tube - Dipstick has surface rust
    --20 shipped
    Crank timing belt pulley - Has surface rust - Whats in the picture is what you get
    --25 shipped
    A/C tensioner Bracket
    --15 shipped
    Door stop thing lol, not sure what it is called. Does not include arm, seemed fine when removed.
    --5 shipped
    Hard intercooler pipe on front of motor
    --15 shipped
    Fan resistor from a 1st gen fan assembly - Worked fine when removed
    --15 shipped
    Coolant reservoir cap with hoses
    --10 shipped
    SOLD:
    Top Timing belt covers - No cracks
    Rear injector harness
    Timing tensioner bracket - Has some rust
    --15 shipped
    Set of 2nd gen heads - Stock, 90k on them I believe - Includes everything shown, cams have surface rust, should be able to clean them though, and cam gears have rust. Heads were working fine when removed, but should be cleaned and lifters replaced at a minimum, they came from a motor that spun a bearing. Currently coated in LPS-3.
    --275 shipped
    Misc engine brackets and heat shields - Make offer (keep in mind shipping from Hawaii is normally a bit more) and tell me which picture and location ex. 1st pic, bottom middle etc...
    Pic 1
    Pic 2
    Pic 3
    Rancho Cucamonga, CA
    Does that ptu only have one month's worth of driving on it?
    No, it was on the J-spec motor I picked up. The motor was only suppose to have about 20k miles on it. I ran the ptu for a month to make sure it was working right.
    Iowa
    I sent you an email. Sorry for the slow responce, I just started my second job yesterday. Let me know as soon as you can...
    ~RABBIT~
    1991 Dodge Stealth RT/TT - In the garage... Close to completion...
    Coil pack and Injectors sold.
    If you need a part here, make an offer.
    Resistor pack sold.
