Results 1 to 3 of 3
Thread: Need SAFC-11 settings
    Ft Wayne IN
    for 15G's, 550 injectors, and boost set at 15psi right now I have everything zero'd out and I would like to get all the info before I do the injector changes. Thanks if anyone can help me out. I know very little about fuel management and tuning, but I'm a quick study! Thanks
    Pauly
    Sep 2011
    1320 Engineering
    take away fuel till the wideband says 14.7 at idle and cruising.
    add fuel till the wideband says 11.5 at wot in full boost. lower than 10 afr - let off. higher than 12.5 afr - let off.
    should be simple enough
    Man vs 3/S verified
    Kingston, WA
    -32% is stock for 550's but 15g's push a lot more air than 9b's, you will have to add more fuel, do what Jonny said.
    You selling stuff again Paul? Always wanted a shifter....
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
