I rewired the driver side AC fan to work as the rad fan. I took the resistor out of the equation so there is only high speed.
Verified correct fan operation with my HHH logger. Fan works on both speed settings. Also unplugged the coolant temp sensor on the water housing and the fan started spinning right away.
Problem is, the car gets pretty hot and the fan still wont come on by itself. Aftermarket gauge reads around 212*F (which is about 206*F on the logger) and the fan STILL wont come on. The old rad fan would come on if it got this hot IIRC.
Why?
