I just got my 550cc injectors installed this morning, planning on tuning with my (reflashed) neo tomorrow. I am anticipating loads of problems, so I figured I would just start my 'tuning troubles thread' now and get some of the baselines out of the way.
PTE 550cc injectors
hotwired supra pump
afpr (with gauge)
apexi neo (reflashed)
13t's
fmic (not a very good one, but it is still an fmic)
fresh copper plugs
WB o2 (which I can log in HHH)
Based on the team3s safc guide, I set my low throttle position to 30% and high throttle position to 85%. For initial corrections I did -30% for high throttle points and -35% for low throttle points.
So far I have only started the car, and let it idle (warm). This went fine, but I had to drop the correction to around -25% for the 1000rpm low throttle point to get the afr correct. The low fuel trim never dropped to 100%, but I am guessing I have to wait longer than a couple minutes to see that move.
So any suggestions, or 'plan of action' ideas considering my parts, would be appreciated, but I think 550cc injectors with the safc or neo have been discussed an awful lot. So I figure I will post an update after things go horribly wrong tomorrow. I am hoping that having a wideband tied into my logging data will make this a snap...
