Originally Posted by
BaadVR4
No problem at all. When the crankshaft journal surface and the bearing surface are close to the same hardness, it is easier for "galling" to occur under marginal lubrication and/or excessive heat conditions. Galling is a phenomenon where two metal surfaces with relative motion weld together, then tear apart. It is most common in press fit wrist pin/pistons, because the piston and pin move relative to each other, but have zero relative motion at both TDC and BDC.
Nitride hardening the journals reduces spun bearings by reducing galling and by making it more likely that small debris will imbed in the softer bearing material and not scratch the journal surface. Hope this helps.
