Results 1 to 10 of 17
Thread: Interior lights - LED
    Cazenovia, NY
    What happened to all the write ups on the interior LED conversion? Basically, I know how it all works, but I wanted to know what LED specs people have used that work well and where they were purchased. I remember there was a TON of write ups over on 3si, and now I can't find any.
    Never finishes any verified
    Wake Forest, NC
    Toni had a great write-up and install guide but it looks like he took it all down.
    PM him and see if he still has it all.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    Here ya go. It should open with IE.
    LED Modification
    1993 Dodge Stealth RT/TT - For mod list, visit stealthTT.com.
    Old site went down... follow the directions in my sig, it should work
    Cazenovia, NY
    Thanks StealthII. It works great in IE. And thanks Toni for the info.
    I purchased 100 7000mcd 3.3V .02A white LED's today and 100 560Ohm 1/2W 5% resistors today. I will be following the writeup closely for tips, and possibly do my own innovations as well. My white center gauges are always lit, but they dim at night when the interior lights come on (so they don't blind you at night). I think for the main gauge cluster, I will find a way to mock that, so my main cluster is always lit up with my center gauges, and dim when I turn the parking lights on
    Should be a fun little project.
    Rancho Cucamonga, CA
    I want to see some pics when you do it
    Here's a general idea of what yours should look like. Took about 10 hours to get most of the LEDS put in.
    bslade
    Guest
    Here is the Blue version using Toni's guidelines:
    Took a long time in the winter in a very cold cold cold garage at nights....
    January 2001
    Dallas, TX
    Is there a way to get the main and center gauges to change colors, like some aftermarket gauges do, with a switch?
    Hey, when you turn your car on, does it return the favor?
    Quote Originally Posted by Michaels_RT
    The NA isnt a pain in the ass. Good car actually. TT...not so much...but a LOT more fun to drive.
    Jan 2011
    they make color changing leds but i dont know if you could make them work
