Results 1 to 4 of 4
Thread: Head Thickness. Experts please
    August 2003
    Uniontown
    Exclamation Head Thickness. Experts please
    I need to know the minimum head thickness for my heads before it is a problem. As they sit, perfectly level, no warp, they are 5.183 inches, and 5.184 inches thick.
    My machinist tells me I will need shims between the block and the head gasket.
    What do I do?
    Medford OR
    So they've had .016/.017 machined off... That's not enough to cause major problems, but it will change your cam timing slightly. If it's a performance build, I'd recommend adjustable cam gears and degreeing the cams. But if it's a stock rebuild, you'll never notice the difference.
    Do they even make shims for these motors? I've used them on a lot of Toyotas, but never had a call to even look for them in this application.
    What he said. I've never seen anyone use shims on these engines.
    OG Member verified
    Sep 2011
    Elkhart, TX
    I have yet to see shims, but have seen extremely thick (+.250") copper headgaskets on a botched deck blocking job that came in about 5 years ago. With that little of a difference, perhaps a slightly thicker headgasket?
