Results 1 to 10 of 12
Thread: Are these N/A Injectors?
    Jul 2011
    Huntersville, NC
    Parts man at the dealership pointed out that these do not look like the stock NA injectors...that they looked more like stock vr-4 injectors. So here is a pic so someone can check theirs and help me out. This is on a 96 SL.
    Cannot tell by just looking. You are going to have to pull one to look at the part number on it. to me it looks like the flash washed the picture out and they are "pink tops". If thats the case they are likely NA injectors.
    Jul 2011
    Huntersville, NC
    Not sure if its because of the age of the injector or not but they are a pinkish color.
    Pinkish color are non-turbo... those aren't brown enough to be turbo injectors
    Yeah. All the NA injectors I have sen have been pink or green. Those definitely look pink as I said. If you want to be 100% sure, pull one and look for something like BDH210.
    MOUSTACHE AFICIONADO
    Sep 2011
    DARDAGO, ITALY
    Agreed ^ My turbo stockers were brownish.
    The only time I tried the local dealer parts dept for anything I could barely get them to acknowledge that Mitsubishi ever made a car called a 3000gt, it's cool that your dealer is trying to help you out.
    1991 VR4
    1995 SAAB 900 SE (Daily Driver)
    1998 S-10 (Still in the USA...)
    Apr 2011
    Mid-April 2011.
    Monroe WI
    They are the same color as mine...arent stock 3/s more yellowish. N/a injectors are green or,a reddish tanish strange color
    The NA injector has the green tip and is more of a pinkish or orange color and the TT 360's are brown. If your car is running the wrong injectors without fuel control it would run like total shit. Very rich
    Edit: oh and yeah I'm about positive those are NA injectors.
    There are some NA injectors that are green topped too.
    Yep, I thought there was, I could have swore I had a set of those in the garage but couldn't find them. I had that typed before but deleted it after I found these and took a pic. I'm pretty sure my old engine had them and I was a bit confused when I was swapping around injectors on my TT conversion.
