Ok, for those of you who were talking with me in chat today, I was doing some further thinking, and stuff isn't adding up. For the rest that weren't around, here's what's happening.
I was on my way home from school today, and after pulling out of the parking lot, driving normally, no boost or the like, my car started 'wobbling', as though I had a flat tire. It evened itself off after a few seconds, so I thoughtit was the pavement. After going from the stop sign I had pulled up to, the car stopped shifting correctly from second to third, but then when I tried again, it went fine and I thought nothing of it, til I drove 200 yards, took a right turn, and it did it again in every gear.
The symptoms I have are:
-I can shift into any gear, engine on or off, and the slave cylinder is pushing, although I'm not sure if it's pushing far enough
-I can hear a vacuum leak near my plenum/master clutch cylinder, but can't pinpoint it yet
-my prosport oil gauge is registering over 100 psi, engine on and off
-there is a quitter clunking/rattling around in my motor. Sounds loudest near my front head and lower intake
- I am idling at double the rpms
- the clutch reservoir is full, but suddenly, the brake reservoir is below the minimum line.
Anyone got any ideas? I'm thinking maybe the vacuum line for the clutch went? Could that cause all that? All these happened at the same time. I am positive on this as I was just poking in my car last night. Thanks for your help
