I never thought this would need to be a thread.
When I turn on the wiper circuit without the wipers attached it pops fuses.
I took everything out of the engine bay to paint it and instead of popping the ball off of the crank arm on the wiper motor I took the arm off.
I didn't mark it because I didn't think it mattered, still don't know if it does.
The motor works fine on the bench, and without the motor plugged in the switch works fine and I get voltage in both the high and low speed terminals on the connector.
As soon as I put it all together it blows the fuse.
Using a small car charger on the 2 amp setting I can work the motor in the car. I watch the nubs and they park in the wrong place. I have tried in a few different places, but I'm out of fuses now, so until tomorrow...
BTW, it worked fine before I took it apart, so the parts should be fine...
