Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Help with front oil return line.
    You will have to disconnect the turbo's water lines anyways if you plan on removing it so it'll all drain out then (which would be more of a mess then if you just drained the radiator).
    Texas
    You can remove the turbo with the radiator in, but it's a royal pain. You may as well remove it.
    Agreed. The only real other way to do this is to remove the front motor mount and bracket.
