I finally had some time to put the motor I bought into my VR4. I am nearing the end of installing everything.
I got everything in the engine bay hooked back up. All I have left to do is the transfer case and driveshaft. The suspension and brakes. Driver side axle still needs to go in and the exhaust needs to be connected.
I found I was missing a purge control valve so as soon as one of those i will install that.
Now my question: I should be able to start the car as it sits. It turns over fine but did not fire. I checked the fuel rail first and it is getting fuel. So next I will check for spark. Nothing that I left undone should cause it not to start correct ?
cant wait to get on the road as I have never driven this car !
