Results 1 to 9 of 9
Thread: Taller in front after ECS strut replacement
    North Bend, WA
    I just replaced the ECS struts on my 3000GT and now the front of the car is 1/2" taller than the rear of the car. I did some searching and it looks like it could be the Strut insulators that are the problem. Strut insulator bearing madness
    Is there anything that can be modified to drop the front back to stock height? Is this going to cause any problems if I drive the car like this until it's fixed?
    I'm Kind Of A Big Deal Feedback Score 8 (100%) Emilie@GZP's Avatar
    Did you put the top spring mount in line with the lower spring perch? There is a hole in the lower perch and the upper spring mount that need to line up.
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
    It should go away and it should be fine to drive it.
    North Bend, WA
    I didn't install the parts myself. I'll ask about that when I take the car back in.
    North Bend, WA
    I thought only replacement springs settled on their own, but struts do not. Is that not correct?
    The aftermarket insulators are taller than the stock ones. When I did mine I bought the aftermarket ones and noticed how much higher they were so I retuned them and bought stock ones. After I realized the whole thing was rubber I think they would have been fine but the stock ones were still better. From what I remember it doesn’t take too long to break in and start to look normal. Anytime you replace struts you need an alignment though.
    Quote Originally Posted by mrbaseball View Post
    Did they replace the insulators when they did this?
    North Bend, WA
    Yeah. I used all OEM parts so I didn't think I would have this problem.
    Yeah it should settle in soon. I wouldn't worry at all. If it doesn't then you might want to check out their install.
