Results 1 to 4 of 4
Thread: Need Some Blitz SBC-ID help
    My Truck is Faster Than My Car
    Lander, Wyoming
    I got a Blitz SBC-ID off the "other forum" and I can't seem to get any boost above wastegate with it. I pressure tested and came out good to 15 psi, and tried running open wastegate and the car will hit 15 psi no problem. Its pretty hard to mess up the install. In is my boost reference off y-pipe and out is a line thats split to each wastegate.
    The monitor is working correctly and it doesn't matter what I change the boost to I will only peak out at ~6 psi.
    Can anyone shed some light on what I messed up?
    Thanks, I'm really new to the EBC stuff, I just changed over from MBC
    Levi
    Levi
    '92 3000GT VR4
    16T's, 550cc, SAFCII, Coilovers, etc
    2004 GMC CC/SB Duramax LLY - Built Motor, Built Trans, 80% overs, S483 over 72vgt, nitrous
    The Garage Queen/Show car - 1969 Ford Mustang Mach 1
    One fix at a time verified
    Kansas
    Do you have the settings on internal or external wastegate? I haven't messed with mine for awhile but you may have to increase the gain and boost setting. If everything is installed correctly and the settings are right it should work just fine.
    Lander, Wyoming
    I haven't checked the wastegate setting. But I set the boost to 14 and the gain to 6 and still the same thing occurs....~6-7 psi. I guess I'll play with it some more
    Lander, Wyoming
    Okay, it is set to actuator and I still can't get it to boost over wastegate boost, no matter what boost/gain I use. If I switch it to wastegate, it acts like open wastegate just free boosting. Anyone?
