Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
Thread: EMS Starting And Tuning Help Please
    Advanced Tech? verified
    scratch that, this new one should have pump prime turned on.
    Attached Files Attached Files
    Im going to try it right now....be back in 10 mins
    No go, same results just clicks its ass off, no sputtering no nothing.
  4. #24
    Banned J. Fast's Avatar
    Have you tried viewing your cam and crank periods when turing it over? Which channels are you hooked up to? T1, T2, T3, or T4? Are they rising and falling as you turn over the engine? And you're sure base timing is set correct and didn't skip?
  5. #25
    I have not viewd the cam and crank periods when turnign it over, Im not even sure what channels Im hooked up to, they are rising and falling when I turn it over though. I'm almost for certain the base timing was set correctly. I just had Jim from WI do all my work and make sure everything was in timing. Is there something software related im missing, in terms of setting timing?
  6. #26
    one thing that concerns me is that he's running firmware 1.21 and it says there are a bunch of options that are not set... but they aren't in the user manual to look up. I know that firmware 1.21 is only recommended for certain f-body models, so I wonder if the setup is different for his version.
    -Crank *4
    -Frequency Out *4
    -teeth degree scalar
  7. #27
    -Crank *4
    -Frequency Out *4
    I can go back to a older firmware, and where do I set those options you just listed?
  8. #28
    if you roll back to 1.19 (what i'm using), they're not available. but they're in options -> full list on your cal file.
  9. #29
    If I roll back to 1.19 I can use the cal file that you made? I only updated to the newer firmware because I have the mentality from IT the latest and greatest is the best :-) not the case in this scenario lol.
  10. #30
    All of these options were turned off
    -Crank *4
    -Frequency Out *4
