Continuing from this thread:
Flash tuning results on a stock 99 VR4 - 3000GT/Stealth International Message Center
The car has undergone a lot of maintenance. Been slowly collecting these parts for years! Feels strange having an empty closet again... BUT it feels good to finally build the car of my dreams!
Pretty much everything attached to the engine has been replaced:
Timing belt & accessories
Water pump
Crank pulley
Timing belt + accessory tension & idler pulleys
Thermostat
Fuel filter
Alternator
AC compressor
Radiator & hoses
New coil pack, plugs and wires
Poly motor mounts
ABS delete with OEM parts
New brake and clutch master cylinders
New OEM Throttle body
Krank Vents (small style)
Megan coil overs with Maximal control arms (thank you Paul Dawson!)
Flow matched and remanned 560 EVO fuel injectors (thanks evotuner!)
Denso 310lph (NOT hotwired)
IPS downpipe with custom Billet muffler in place of a cat
IPS quad tip exhaust (coming soon)
Billet DR650s
Forge Wastegates
Forge BOV
EVO 8 MAF
EVO 10 Map sensor (installed before the build)
LC1 wideband
I'm still running the stock air box, intake tubes, innercoolers & pipes (even the plastic Y pipe). All emissions equipment are still intact and functioning. Aside from the wheels and suspension, this car looks completely stock.
Here's the car before the build at NG:
...and here it is now!
What a difference!
This is my exhaust currently. It's an IPS downpipe which I've modified to accompany a 3" Bullet muffler from Buschur Racing. BR makes these Bullet "cat" mufflers for the EVO and it slipped over the IPS downpipe almost perfectly. I had to notch the muffler to clamp onto the pipe better but that was easy with an air grinder. Then I had to cut 19" off the IPS pipe with a SS pipe cutter.
This muffler just BARELY fits under the car. I had to remove the stock underbody heatshield for it to bolt up, but if you're running stock motor mounts, it would hit the bottom of the car for sure. I wish I had the skills to modify the downpipe to sit 3/4in lower than it does to give more room for the "cat".
Had a nice surprise when tearing apart the car too. It always had some idle issues, even threw a CE light for "Idle System Fault". I cleared it up fairly well playing with the timing & fuel tables as well as adjust the BISS, but whenever the temperature outside was above 85ish degrees, it never wanted to idle while cold.
Found out why... Not sure how I never noticed this before:
Good thing I had an EVO 8 MAF to replace it....
Continued in next post!
