Hey guys,
I have some weird problem with the third brake light on my 95' GTO SR. Let me start with the info that I have installed custom LED tails first, because I am not sure if that could be part of the problem. Anyway, my car came stock with the N/A spoiler on it, but after a while, I got and installed an A/A wing in its place. Somewhere in that time, I also bought and installed a Buldog remote start and keyless entry system. The LED tails needed some diodes installed in the wiring, because otherwise they didn't work properly. So, when I did that, everything worked fine - LED tails, remote starter & keyless entry and the A/A wing.
Well, after some more time, I decided to get a hoop spoiler and after I installed it, the remote starter would not work properly anymore. What happens is, when I remote start the car, the engine starts and all, but when the tails kick in (that's how the remote starter is designed to operate - after you turn on the engine remotely, the running lights come on until you press the brake or until certain amount of time goes by), the engine shuts off... I thought the problem was in the third brake light of the hoop spoiler since the scan of the car showed a code for it, so I connected a Stealth spoiler to see if that would fix the problem, but it didn't. When there is no third brake light connected, the remote starter shuts off the same way.
At some point, I thought of connecting the A/A wing again to see if all was going to work fine as it did when I had that wing on the car and viola - it worked! So, I thought the problem was in the different wattage of all the third brake lights and I bought resistors - one was 5 watts 1.8 ohms (1.8 ohms is what the resistance of the third brake light of the A/A spoiler was so that is why I got that resistor) and the other was 3 watts 1.8 ohms resistor. Well, neither one fixed the problem!
I am at a complete loss as to what I can do next to fix this issue. Does anyone have any clue what could be causing this and how I can fix it? Any input is appreciated. Thanks!
