Results 1 to 5 of 5
Thread: 1992 Stealth RT $2000 OBO
    Kalamazoo
    1992 Stealth RT Reduced - $1500
    1992 $ 1500 OBO
    Need a donor car? I might have what you need...Here's the story.... lady decided to turn left in front of me even though I had a grand total of 20 feet between me and her in the intersection, so I obviously smashed right into her. So now I'm going to sell it. I dont have the finances or the time to try and fix her up right now. It's a 5 speed, N/A RT.
    To my knowledge (with what I can see from looking around) the frame is fine. If there is any specific pictures that you want to see, please do not hesitate to ask.
    Apart from the obvious damage to body and paint, the rear bumper has some paint missing off of it on the passenger side. It looks as if the lady who had it before me backed up into a bush or something and it scraped off. You see the black plastic of the bumper. There is also a dent right behind the drivers door...one of those where you see it more as you get closer to it kinda thing. A deer decided to ram its head into the side of my car driving to work one morning. That was pleasant.
    Miles on the car....body has approximately 175k on it. Odometer reads 68,267. When the previous owner took it into a shop they put some belt on it that was too large, or something of that matter from what she told me, on it and it tore apart some things...so they had to replace enough in the engine that it required a new Odometer put in. I also have the old odometer that reads 107,486. Lastly, there's a sticker that you can see when you open the drivers door that says the shop replaced the odometer at this mileage. I bought the car when the Odometer read ~22k, 4 and a half years ago. If you need/want more info on this I can try to be as best help as I can.
    It still starts and runs apart from what sounds like a squeaky belt when I rev it a little. I can also get a video of this if you would like to hear it. Because of the damage done on the passenger side, the ABS unit (I believe) was jammed in such a way that the tire on that side will turn a few inches and then run into the unit. You would definitely need to tow it to get it where you're going.
    Attached are some pics that I took, just so you can kind of see what you would be getting into. Obviously, things I'm pointing at are the concern areas, such as the thing that hits the tire when you turn the wheel. Be sure to look at the next posts for the rest of the pics.
    So there we are. Again, if there are any pics of anything you want, please let me know. Any other info you want, let me know as well.
    $1,500 OBO, since it's still in running order and just body work needs to be done. I am really motivated to sell this though. The faster it sells the faster it's out of my garage and I can help pay for the other car I just bought. Car is located in Kalamazoo, Michigan.
    Thanks,
    Josh
