Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 121 to 130 of 131
Thread: Overheating with TD05 turbochargers
  1. #121
    The Panda Not Verified
    Washougal WA/Portland OR
    CXracing FMIC + trans cooler = your problem!
  2. The Following 2 Users Say Thank You to vr4tune For This Useful Post:
  3. #122
    i agreed with j.fast, although i have to wonder if he was living in phoenix or miami if the same results would hold sway.
  4. #123
    Known as SLGuy
    Owens Cross Roads, AL
    Guess its time for somebody to make a road trip!
  5. #124
    Forum User supporter
    Bounemouth, UK
    Quote Originally Posted by PaulL View Post
    I've read some threads stating its a good idea to add some support to the rear manifold to prevent it from cracking. What's your take on this?
    The rear turbo already does have some supports welded on to the manifold, it is second nature for the stainless manifolds to crack due to the way that stainless expand and contracts when heated and cooled the welds are always going to be the weakest part of the manifold as they create a hardened area eather side of the weld, the best way to avoid this would be to have thicker wall manifolds but there is always going to be a weight trade off.
    As I said in my original post, the cracks in my manifold could easily been caused by the turbo being slamed up against the bulkhead by hard launches with very shot engine mounts, the force would be like hiting the manifold with a sledge hammer.
    Jeff
  6. #125
    Known as SLGuy
    Here's a question regarding fabricating ducting, I know thin aluminum sheets can be used, but what kind of plastic can I buy to make plastic ducting that is a similar material to the OEM ducting?
  7. #126
    Oh, and at one point in time I ran the biggest SMIC's ever made, the most efficient cores, GENE's huge SMIC's.
    have you a longer post about your results posted somewhere?
    1996 GTO, Owner since 2003.
  8. #127
    Ann Arbor, MI
    I'll look into this at work today. Ideally you want something you could lay a straight edge across and bend into shape. There are a couple of options but the material names are escaping me.
  9. #128
    just another thought i had today on the copper vs. aluminum argument....
    cotton absorbs more moisture, but under-armor wicks it away faster.
  10. #129
    I don't bite
    Southern IN
    Hood extractor vent.
  11. #130
    Apr 2011
    on and off since 05
    Romulus
    Sorry for not having chance post results. I trim the upper openings to give it 3and inches off the intercooler. The cover made a natural ducting effect and car runs cool like it should drove it for 2hrs today no issue so thanks to alex3000gt.
    Nathaniel Colton Orr Born 12/23/2011 6lbs 13oz, 20 inches healthy as can be for being early!!!!!!!!!
    BEST EARLY CHRISTMAS PRESENT EVER A SON!!!!!!!!!!!!!!!!!!!!!!!
    92 Stealth TT R/T
    Mods: t30 ball bearing turbos, IPS FMIC, AEM V2.0 standalone, Tial BOV, Ksport struts, Tublar upper rear control arms, VOLKS 18 inch 2 piece wheels, AEM Wideband O2, AEM True Boost, 780 injector, IPS fuel rails, AEROMOTIVE FPR, FM Oil cooler, RPS Flywheel, Kevlar timing belt, hose candy silcone lines and fittings, krank vent system, single pass 3sx radiator soon as I finish getting all parts installed in trans, 6 speed trans with dog box and Torison Diff ,and Kaaz rear diff
  12. The Following User Says Thank You to propbreaker For This Useful Post:
