I have a 150K mile SOHC montero engine apart, and just at that mileage oil buildup can be BAD.
On the old set of pistons I meticulously cleaned up by hand, I'd say 95% of the oil-holes around piston rings were clogged shut. Typical of most high-mile engines, the amount of 'permanent' buildup on the pistons/block/valves/etc old hardened oil residue can be horrible.
I say permanent in a sense of no 'engine clean' wonder product or anything you'll add into your oil will ever clean completely off.
That engine is going together with the crankshaft from my old 275K+ mile Stealth, crank is good and machine shop just polished. They also pressed 6 Stealth rods onto 6 Montero pistons for me. New STD rings and bearings.
I mean to get to the point, I have some experience with engine semi-rebuilds. The surgical care required in assembly, and the quick cleaning/oil changes that should occur a few times quickly after the newish engine runs.
This particular '91 Talon being fixed has 98K original miles.
1K miles ago, I did some work. Stock rods were modified to fit new 2G nippon racing pistons. New STD size rod bearings & piston rings.
The recent failure, was caused by a coolant hose that sprung a leak. I ran empty and hot extra long- radiator fan issue I was still dealing with, once its THAT hot and you realize you know its too late.
Anyway I work with the ACTUAL world and what I can judge while its being inspected, I'll see if I can get it and keep it running good this time..
