Results 1 to 10 of 19
Thread: Click click click click
    All I hear is my mfi relay clicking when I try to start. I've checked the ecu and the caps are fine to my surprise. What could it be?
    Have you tested the relay itself?
    August 2003
    Uniontown
    I just replaced my actual starter switch in the column. What the cylinder rotates when you turn the key. Fixed my no start/clicking problem. No more turning over problems again. Something to look at if you find the relays good, and of course the starter.
    Try simple stuff first. How's the battery?
  5. The Following User Says Thank You to stealthee For This Useful Post:
    12.56 at the battery im gonna test the relay
    Sent from my PC36100 using Tapatalk
    Man vs 3/S verified
    Kingston, WA
    Are your headlights switched "on"? Mine will click click click infrequently if my headlights are in the "on" position when starting.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  8. #7
    http://s24.photobucket.com/albums/c4...=VIDEO0001.mp4
    Heres what it's doing.
    Testing the relay now
  9. #8
    Aug 2011
    GA
    I would definitly check relay (which I know your doing) and try jumping it. Also if you have a O scope test for signal pulse.
  10. #9
    San Francisco
    My MFI relay would click when my starter was bad.
    Support NG!
  11. #10
    Replaced the starter still clicks... 12.8 volts at the starter I've tried a different battery. The car did start once but now I noticed there is a relay missing in box in the engine bay in the starter spot... Does this need to be there?
    its the blue one thats marked starter on the cover
